Can't get generated mesh to show up in edit guides modifier
Posted by:jducey
Data created:15 December 2013
I have a modifier stack consisting of guides from surface, edit guides, hair from guides, render settings, and mesh from strands. I want to be able to view the mesh from within the edit guides modifier so I can position it correctly, but all I see are the guides, although the mesh appears in every other modifier in the stack. I got it to work before somehow, but I can't reproduce the effect, so I was wondering if someone could explain to me how to do it. Thanks!
Do you have show end result on in the modifer stack? Maybe you could post a screen capture of your stack and what you see in the viewport.
Michael
Oh, duh, it must have gotten disabled somehow. Thanks! That fixed it.
