Dynamics global scale.
Posted by:ramous62
Data created:12 May 2014
OX 2.5.7.0
I have a very simple scene using massfx for dynamics.
I rescale global scale but this has no effect. Why?
Also it is very flaky, the dynamic seems to break and stop functioning.
You have to start from scratch and redo everything to get it to work again. Why?
>boy+test05.rar (141730 bytes),
the scene with dynamics that wont recale.
the scene
>boy+test06.rar (140769 bytes),
Howdy,
There are no dynamics in this scene but if I add a OX Dynamics mod I can see the default in the scene has to hight a Wisp Size. If you bring that down to 1 or .75 I think you'll have better luck simulating. If that is not your issue, please post your scene with a set of simple steps to reproduce what issue your having. ie:
1. Open the scene
2. Press simulate
3. Hair flies off into space
PS Always avoid using a Turbosmooth below hair in the stack. It can invalidate the stack by changing the topology unexpectedly.
Michael
Did you open the one above your comment?
The wisp size helped but now it looks as though gravity is way too strong.
Should I change Massfx gravity or OX global scale control, I assume thats what it's for.
Doesn't seem to have any effect.
You can try to reduce gravity or the Hair Density. I would suggest the Hair Density first.
Michael
Cheers
