Transferring OX modifier and groom from static to animated mesh.
Posted by:dmaertz
Data created:18 September 2014
Hello All,
I have a bit of a complicated question. So my basic workflow is to groom my model and then copy the modifier stack to a animated version of the same mesh. I figure this would be simple enough, but apparently I was wrong. When I pasted the modifiers onto a referenced version of the animated mesh the hairs got significantly shorter and the surface comb completly broke. Is there a good workflow solution for this kind of problem? I am kind of stumped.
Thanks in advance.
-Dustin
Hi Dustin,
Do you think you can reproduce this in a simple scene which you can upload here or send me?
Thank you
I would gladly send you a simple scene. Can I please have your email adress, or I can sent it to Michael.
Thanks for the quick repley.
Email sent, found your contact info.
