recognize the hairy normal map?
Posted by:vivecommunications
Data created:22 January 2015
Literally.
...My English is not good.
How would you like to use a normal map?
Michael
normal map with the object, rather than using a normal map to the hair will become care or is applied to the hair.
When hair is getting its UV's and color from the underlying surface it should not be using a normal map because that will not provide any important information to the hair. In this case mostly the color is taken from the map below and normal or bump info does not come into play.
Michael
