Hi, I try to make a haircut like this, but I've problem with the UV at the end of the workflow.  Do you have a idea ? Patrick |
| Hi Patrick, Are you using mesh from strands modifier? If so, what are your settings there? It looks like you are ucing cylindrical hair option. Please try turning off per-strand UVs option to see if that helps. Also please let me know what type of UVs you'd like to have. Marsel Khadiyev (Software Developer, EPHERE Inc.) |
| Please see my strands modifier setting : (same thing : UV problem) Attached Files: |
| It is possible that the cylindrical hair mesh only supports per-strand UVs, I will have to do some more investigation on this. Are you able to achieve the desired UV effect with billboard strand method? Marsel Khadiyev (Software Developer, EPHERE Inc.) |
| Yes working with the billboard strand. But it's not the desired effect for my character. |
| Ok, thank you. I will see what we can do about this. Marsel Khadiyev (Software Developer, EPHERE Inc.) |
