| Posted by: | exnpac | |
| Data created: | 14 September 2015 | |
I have encountered this error many times : System.Reflection. TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.TypeInitializationException: The type initializer for 'Ephere.Utilities.Evaluator' threw an exception. ---> System.IO.IOException: The process cannot access the file 'C:\Users\PaccoAdmin\AppData\Local\Temp\feylwyuv.dll' because it is being used by another process. at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost) at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, String msgPath, Boolean bFromProxy) at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share) at Microsoft.JScript.JSCodeGenerator.FromFileBatch(CompilerParameters options, String[] fileNames) at System.CodeDom.Compiler.CodeCompiler.FromSourceBatch(CompilerParameters options, String[] sources) at System.CodeDom.Compiler.CodeCompiler.System.CodeDom.Compiler.ICodeCompiler.CompileAssemblyFromSourceBatch(CompilerParameters options, String[] sources) at Ephere.Utilities.Evaluator..cctor() --- End of inner exception stack trace --- at Ephere.Utilities.Evaluator.EvalToDouble(String statement) at Ephere.Gui.NodeViews.Skin.Area.GetLeftValue(Dictionary`2 parameterValues) at Ephere.Gui.NodeViews.NodeView.Node.LayoutNodes() at Ephere.Gui.NodeViews.Schematic.ValueNode.LayoutNodes() at Ephere.Gui.NodeViews.Schematic.InternalInputsNode.LayoutNodes() at Ephere.Gui.NodeViews.Skin.SetBoilerPlateSchematicView(Schematic view) at Ephere.Gui.NodeViews.Skin.get_Default() at Autodesk.Max.StateSets.Plugin..ctor() --- End of inner exception stack trace --- at System.RuntimeTypeHandle.CreateInstance(RuntimeType type, Boolean publicOnly, Boolean noCheck, Boolean& canBeCached, RuntimeMethodHandleInternal& ctor, Boolean& bNeedSecurityCheck) at System.RuntimeType.CreateInstanceSlow(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark) at System.RuntimeType.CreateInstanceDefaultCtor(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark) at System.Activator.CreateInstance(Type type, Boolean nonPublic) at System.Activator.CreateInstance(Type type) at Autodesk.Max.Manager.LoadAssembly(String name, Boolean startingUp) at Autodesk.Max.Manager.LoadAssemblies() I tried a full reinstallation of windows (my computer needed it), updates, last version of max, etc. I didn't find the answer on internet either. Fortunately, I found that max launched without this error message poping at start when I started it directly after logging into windows. I found out that it was actually the antivirus Panda security that was causing this. |
