Alembic export issue
Posted by:ratus
Data created:29 August 2016
hello,
I having hard time to use any alembic file exported by ornatrix
So I have done a simple sphere in 3dsmax 2016, put a quick hair fur on top of it and export as Ox Alembic file
Ox generate a 2ko file so there's some info in it but when I import it in 3dsmax 2016, nothing shows up in the viewport and I can see a NURBS Surface in the Modifier stack but that's all
I've tried to import it in modo but modo is unable to import this file
thanks
3dsmax's default Alembic importer cannot import Alembic hair curves. You have to use something like VRay proxy object to import Alembic curves. Not sure how it works in Modo, never used it.
thanks for your fast as lightning reply Marsel !
