Run Ornatrix from server
Posted by:frodo
Data created:21 April 2017
it is possible to have ornatric installed on server and then load it to Max via plugins.ini? With vray,forest its possible but it need some enviroment variables on the system. So is the a way for Ox?
Hi Frodo,
I think this is what you are looking for: https://ephere.com/plugins/autodesk/max/ornatrix/docs/5/Starting_and_Activating.html
Nope,
I have no problem with licence. I'm asking if possible to load Ox from server no from local workstation.
Same think as for vray here
https://docs.chaosgroup.com/display/VRAY3MAX/Running+V-Ray+from+an+Arbitrary+Location
I can't remember if there is anything that prevents Ornatrix from loading from a network location. Why don't you just give it a try?
There are two files which need to exist for Ornatrix to load:
This is the Ornatrix itself, which can be loaded from a network location: Ephere.Plugins.Autodesk.Max.Ornatrix.dlo
This needs to be present in 3dsmax root, or some directory which is part of PATH so 3dsmax can load it when needed: Ephere.Plugins.Autodesk.Max.Ornatrix.Authorizer.dll
Thanks,
this is what I need and it works :)
