#I noticed that if I merge a model with ornatrix fur in a scene with different system unit, the geometry will be imported at the right size but the fur will have wrong lenght and it seems impossible to fix this without redoing the entire fur.
I also tried the rescale world units utility that is suppode to rescale selection or scene, but the fur is not scale properly, the root will be attached at the right place but the lentght will not change so it becomes really long in my case. And if I try using the add length modifier, I loose all my edit guide modifier changes.
How can we scale a model with fur properly?
I am preparing models for Turbosquid (an insect) and for checkmate pro I need to set it at real world scale. But if someone is using max default scale, he will not be able to use my model?
