A different method to interpolate?
Posted by:njen
Data created:28 May 2018
Is there anyway to smoothly interpolate between the guides in the attached image? The best settings I can get are 'Afine Interpolate' and 'Interpolate between two guides'. Any other combination of settings produces much more undesirable results.
Oops, forgot to attach the image.
I will do some tests. How are you generating the hairs?
Hello, I was wondering of there has been any movement in both of my issues. Btw, the file that illustrates both issues can be downloaded from the other thread:
https://ephere.com/plugins/autodesk/max/ornatrix/forums/general/thread_8185.html
Thanks!
Thanks for the file. I think both problems are related. As I said on the other post I think the problem is the method to create the hair and something is effecting the interpolation. I will investigate and get back to you.
