Im trying to create hair by using shapes as it's easier to control the shape and direction of the hair. However it's not working properly. I create a few splines and applied Guides from Shape on top. After adding Hair from Guides this is what Im getting. Does anybody know why?
Which distribution method did you use in Hair from Guides? It needs to be anything except "guides as hair". Also make sure in Ground Strands that you have the "Detach Strands" button pressed off.
I think you just have to ground the strands on OxGroundStrands modifier. You can find the documention of GroundStrands HERE, and a tutorial explaining the process HERE.
