Hair from Guides does not make intended hair
Posted by:Shun
Data created:10 June 2018
I watched this tutorial and tried making hair from splines.
iZiDEOVavFg
I made a simple plane as scalp to make hair,
and I added Splines to make some guides.
However when I create Hair from Guides,
some hair doesn't follow the nearest guide.
guides
params
Could you tell me what I am missing ?
Try using Affine interpolation in Interpolation Guide Count section. Then add a Strand Clustering modifier the bring the hair together.
thank you for your help,
it looks better now but still doesn't look right,
I think the hair from the back side of scalp mesh doesn't follow the guides, (which I don't need anyway)
is there a way to make hair from guides only from the front side of the polygon mesh ?
Well I found what to do myself,
uncheck the Use UV Coords and it works well.
