Zookeeper Error
Posted by:Adrian
Data created:19 January 2011
I installed the demonstration version of last Zookeeper for 3ds max 2009 x32.
When I'm trying to open the zookeeper window and error message apears:
System.TypeLoadException: Method 'CreateUnmanagedWrapper' in type 'GlobalCUIPosData' from assembly 'Autodesk.Max.Wrappers, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null' does not have an implementation.
   at Autodesk.Max.Global.get_CUIPosData()
   at #=qabcv_i0TokMwvXBKk6Ppi4SALSQ1C7a5ZI77gdbt1y4VtQWBv2axT6JbKByWi0CBsAGo3HRaUo4pJRSwndJpdA==.  #=q4Dy16tSk2CjgZ6NUuCLCE4fsFZZ5bDc$DKC9sOBny$U=..ctor(  #=qabcv_i0TokMwvXBKk6Ppi4SALSQ1C7a5ZI77gdbt1y4VtQWBv2axT6JbKByWi0CBsAGo3HRaUo4pJRSwndJpdA== #=qSxoif7y8kv_Ty4w0_CWubQ==)
   at #=qabcv_i0TokMwvXBKk6Ppi4SALSQ1C7a5ZI77gdbt1y4VtQWBv2axT6JbKByWi0CBsAGo3HRaUo4pJRSwndJpdA==..ctor()
   at Ephere.Plugins.Autodesk.Max.Zookeeper.Plugin.#=qCcWVlJajtKhxr1alwZnIow==()
   at #=qQxWZgmatejE9J5R4zf0zLFAucEdqr0RWa9Cgzj2sRzTlv1L7Rw8uS0lW$bsC3sWYneH30xR6qeRRtgSWe9caFw==.ExecuteAction()
   at Autodesk.Max.Wrappers.ManagedWrapperActionItem.ExecuteAction(ManagedWrapperActionItem* )
No mater what action I choice (other than Reset) this error appears...
How can I fix that?
Thanks.
This is a known issue and we're currently working on resolving it. Thanks for reporting it, hopefully won't be long until its fixed.
Please note that 2010/2011 versions of ZK work OK, just 2009 is affected.
Thanks!
Waiting for the fix. Can't wait to try it.
Hi Adrian,
It should be all fixed now. Before installing, however, please remove file Autodesk.Max.dll from your 3dsmax root directory so that it is installed again.
Thanks!
