| Posted by: | sebastian___ | |
| Data created: | 4 February 2011 | |
The Zookeeper concept is very interesting, Unifying all in one schematic view. Also as a request - the option to use a single click instead of double click for synchronizing the Material Editor with Zookeeper. | |
| 4 February 2011
#2642 | |
Hi Sebastian, Good suggestions about preset layouts. This is something we have been talking about and will be looking into for future releases. I use ZK for materials on a daily bases. Any sugesstions to make that better are very welcome. Here are a couple things that might improve your workflow. CTRL click the + sign on a node to quickly expand all its inputs. I use this for materials and maps all the time. In preferences you can set how many nodes this will expand out to. This way if you only want one or 2 levels for maps you will not get additional controllers etc. Use the show inputs only mode. This will only show connected inputs so the view has very few rollouts and parameters. If you then drag and output from a texture to say a material only the accepted inputs will automatically become visable. You can explore setting up custom UI layouts for nodes you use very often. This way they will always show up with the rollouts you use 98% of the time only. Hope that helps. Thanks so much Michael McCarthy | |
| 23 July 2011
#2797 | |
I'm not using zookeeper for current projects, but I will definitely use it in the future, and I made these tests with an older demo so apologies if things are different with the current version. http://img814.imageshack.us/img814/1870/image3wg.png Request - to be able to drag and drop a material in zookeeper
And since this is an advanced schematic node editor it would be interesting to have features seen in other node editors like The Foundry Nuke and others. For example keep a key pressed like ALT and drag a node and the node will detach or reattach somewhere else. Or again with a key pressed (maybe the same key) move a node and touch the other node and a wire will be created. Maybe the last one is more difficult.
| 3 December 2011
#2841 | |
Hi Sebastian, Sorry for the (very) late reply. Just wanted to let you know that this thread wasn't forgotten and we're looking into this kinda stuff. Cheers Marsel Khadiyev (Software Developer, EPHERE Inc.) | |
| 3 December 2011
#2846 | |
Hey, thanks for answer. | |
