Compatibily with TheOnion Layer Manager?
Posted by:cecofuli
Data created:31 March 2011
hope that in the new release, we solve the Layer problem.
Also a request. It's possibile that ZK is compatible with TheOnion Layer manager.
We want to switch to ZK, but right now, with the " import layer bug" and all other problem, it's not possible. Our pipeline is based on TheOnion script.
http://www.scriptspot.com/3ds-max/scripts/theonion
It's possible that ZK recognised the Layer grop make with this script? The layer, when you solve the import problem, is the same as the 3ds max standar layer manager, but the group is from TheOnion.
thanks!
Here a little screenshot
Hello Cecofuli,
We will likely not "support" theOnion script as it is a script and hard keep compatibility with everything out there. We have implemented some options similar to it like hiding Pflow events making them not renderable, and a few other things that were important in larger pipelines.
We are working on the merge layer issue now and the 0 layer issue should be fixed with a simple refresh. The next build will auto refresh to clear that up.
Thanks a bunch
Michael McCarthy
Hi Michael,
I understan :)
Layer manager import features is very important. Also, I hope that we can import a layer group created by ZK.
