| Posted by: | morbid_angel | |
| Data created: | 15 December 2012 | |
Hello, Zookeeper seems like a great tool but I would like to know a few things before buying, which are really important to my work flow in production: - Is it possible to submit different state sets to deadline or backburner to render them as different jobs?
- Is it possible to submit state sets with name tokens, so each state name would be used in the file name of the output?
- Is it possibe to edit recorder properties after they had already been recorded for a state set?
- Does zookeeper work with vray environment fog? in my tests with the demo build I got an exception when I tried to record any operation relating to the vray env fog.
- It appears zookeeper does not understand/record changes to vray render elements, adding/removing or changing the properties, is that planned to be supported?
- It appears that zookeeper does not record changes in modifiers, is that planned to be supported?
Thanks and hope to hear from you soon! |
