zookeper crashes when doing the following (file attached: 01.max): - creating a simple nurbs-setup (two cv-curves, u-loft between them, two extrusion surfaces) - add the nurbs object to a schematic view (scene node: curve 01) - drag out the object input (cv surf) - maximise sub-animatables - drag out the model input - max crashes
This will be fixed in the next build, thanks again.
It turned out to be an issue in Max and the "Model" input cannot be expanded, so this is more of a patch than a full fix. We will contact Autodesk regarding a deeper fix.
