Zookeeper kills keyboard when docked?
Posted by:Vincit
Data created:12 April 2014
Self explanatory Title, Whenever I dock zookeeper it kills my keyboard usage of any shortcut keys in max.
There could be something wrong from my end, however i wanted to check with you if this is of any kown issue before i further investigate.
Thanks.
I cannot reproduce this locally. Can you please give me the exact steps you go through to reproduce the issue? Do you dock in extended viewport or to the side of Max?
Thank you
Hello and thank you for the quick replies in these forums,
Its curious, to reproduce this issue i simply open zookeeper in a fresh scene and check - views - "dockable in 3ds max" after that my keyboard goes dead whithin 3ds max entrirely shortcuts or otherwise.
I dont have to duck it anywhere for this to happen.
Please note this is the latest trial version of zookeeper under 3ds max 2014 with service pack 5.
Thanks,
P.S. if you cannot reproduce this issue still after the mentioned above, i will be reformatting my system soon anyway and will keep you posted if it still occurs then.
No problem. Just tried this here on Max 2014 and it works fine. Can you please let me know which version of Max and Windows you are running? There has actually been another report of this issue so it isn't isolated to you I think.
3ds max 2014 + service pack 5
windows 7 64 bit proffesional
I will try to test it on my colleagues machine tomorrow windows 8 64 bit pro cause my new machine will be running windows 8 64 bit professional.
