I will fix it for next build.
Good!
That will be considered but for now Zookeeper is aimed to be a unified solution (with schematic interface).
Perfect :)
When you have objects selected and click add layer the selected objects are automatically moved to the new layer.
I can't see the "add layer button". Only a "Create a new layer", but the object stay in the old layer. See the video.
Agreed, will look into that
Perfect :)
You can right click and "Select children" which should select any objects if they were expanded.
Ok, but you must select a layer, right click and find a Select children button. 3 operations. Too much time IMO. I think it's better one click solution. Sorry, but I'm fans of "The Onion" and I love SPEED and less click! I use a lot a layers in my work :)
I will look into this.
ooook!
And this too :)
good! And see the video. If I select an object in the Layer 0, the tree expand. It's not useful, because I can't see the "Create a new layer button". With a lot of objects I must scroll up the Layer UI. So I prefer that stay collaps (in some case I think this is useful, but not in all situation). Imanage Layer, not obj and in arch viz, we have scene with +10.000 Obj. I don't nee to see all geometries in the ZK Layers UI.
Do you remember Fangorn? Very good Layer manager, but it's died I think. There is a some intresting idea on that ;). See the Fangorn video ehehe...
http://www.fangornlm.com/
And your new rename tool (useful) i very similar to the old script (so slow with a lot's of object, but i use it every days).Good to see in ZK.
http://www.scriptspot.com/3ds-max/scripts/renamify
Zookeeper is a huge plug. I think if it will be a robust, very fast workflow, useful Layer manager for architect will be perfect! Architect and designer don't need a wire parameter, node Medit (ok, now in Max 2011) etc...
But this is only my opion ^_^
