Receiving crash when trying to ground strands on Metahuman hair
Posted by:leestuartx
Data created:25 January 2024
Hello, I haven't been able to get the program to work. I tried the latest stable and nightly builds. I've checked discord and searched this forum, can't find any answer. Any help would be greatly appreciated, thank you. This is the crash log:
LoginId:56261c744d5a6f30ed2f288286f49454
EpicAccountId:7acc596ce4c44b7a8c04ce20584b011c
Unhandled Exception: EXCEPTION_ACCESS_VIOLATION reading address 0x0000000000000428
UnrealEditor_OrnatrixEditor
UnrealEditor_Slate!TDelegate<void __cdecl(void),FDefaultDelegateUserPolicy>::ExecuteIfBound<void,0>() [D:\build\++UE5\Sync\Engine\Source\Runtime\Core\Public\Delegates\DelegateSignatureImpl.inl:570]
UnrealEditor_Slate!SMenuEntryBlock::OnClicked() [D:\build\++UE5\Sync\Engine\Source\Runtime\Slate\Private\Framework\MultiBox\SMenuEntryBlock.cpp:1167]
UnrealEditor_Slate!SMenuEntryBlock::OnMenuItemButtonClicked() [D:\build\++UE5\Sync\Engine\Source\Runtime\Slate\Private\Framework\MultiBox\SMenuEntryBlock.cpp:1118]
UnrealEditor_Slate!TBaseSPMethodDelegateInstance<0,SMenuEntryBlock,1,FReply __cdecl(void),FDefaultDelegateUserPolicy>::Execute() [D:\build\++UE5\Sync\Engine\Source\Runtime\Core\Public\Delegates\DelegateInstancesImpl.h:281]
UnrealEditor_Slate!TDelegate<FReply __cdecl(void),FDefaultDelegateUserPolicy>::Execute() [D:\build\++UE5\Sync\Engine\Source\Runtime\Core\Public\Delegates\DelegateSignatureImpl.inl:549]
UnrealEditor_Slate!SButton::ExecuteOnClick() [D:\build\++UE5\Sync\Engine\Source\Runtime\Slate\Private\Widgets\Input\SButton.cpp:465]
UnrealEditor_Slate!SButton::OnMouseButtonUp() [D:\build\++UE5\Sync\Engine\Source\Runtime\Slate\Private\Widgets\Input\SButton.cpp:390]
UnrealEditor_Slate!SMenuEntryButton::OnMouseButtonUp() [D:\build\++UE5\Sync\Engine\Source\Runtime\Slate\Private\Framework\MultiBox\SMenuEntryBlock.cpp:434]
UnrealEditor_Slate!FEventRouter::Route<FReply,FEventRouter::FToLeafmostPolicy,FPointerEvent,`FSlateApplication::RoutePointerUpEvent'::`8'::<lambda_3> >() [D:\build\++UE5\Sync\Engine\Source\Runtime\Slate\Private\Framework\Application\SlateApplication.cpp:442]
UnrealEditor_Slate!FSlateApplication::RoutePointerUpEvent() [D:\build\++UE5\Sync\Engine\Source\Runtime\Slate\Private\Framework\Application\SlateApplication.cpp:5206]
UnrealEditor_Slate!FSlateApplication::ProcessMouseButtonUpEvent() [D:\build\++UE5\Sync\Engine\Source\Runtime\Slate\Private\Framework\Application\SlateApplication.cpp:5775]
UnrealEditor_Slate!FSlateApplication::OnMouseUp() [D:\build\++UE5\Sync\Engine\Source\Runtime\Slate\Private\Framework\Application\SlateApplication.cpp:5740]
UnrealEditor_ApplicationCore!FWindowsApplication::ProcessDeferredMessage() [D:\build\++UE5\Sync\Engine\Source\Runtime\ApplicationCore\Private\Windows\WindowsApplication.cpp:2231]
UnrealEditor_ApplicationCore!FWindowsApplication::DeferMessage() [D:\build\++UE5\Sync\Engine\Source\Runtime\ApplicationCore\Private\Windows\WindowsApplication.cpp:2738]
UnrealEditor_ApplicationCore!FWindowsApplication::ProcessMessage() [D:\build\++UE5\Sync\Engine\Source\Runtime\ApplicationCore\Private\Windows\WindowsApplication.cpp:1099]
UnrealEditor_ApplicationCore!FWindowsApplication::AppWndProc() [D:\build\++UE5\Sync\Engine\Source\Runtime\ApplicationCore\Private\Windows\WindowsApplication.cpp:937]
user32
user32
UnrealEditor_ApplicationCore!FWindowsPlatformApplicationMisc::PumpMessages() [D:\build\++UE5\Sync\Engine\Source\Runtime\ApplicationCore\Private\Windows\WindowsPlatformApplicationMisc.cpp:148]
UnrealEditor!FEngineLoop::Tick() [D:\build\++UE5\Sync\Engine\Source\Runtime\Launch\Private\LaunchEngineLoop.cpp:5749]
UnrealEditor!GuardedMain() [D:\build\++UE5\Sync\Engine\Source\Runtime\Launch\Private\Launch.cpp:188]
UnrealEditor!GuardedMainWrapper() [D:\build\++UE5\Sync\Engine\Source\Runtime\Launch\Private\Windows\LaunchWindows.cpp:118]
UnrealEditor!LaunchWindowsStartup() [D:\build\++UE5\Sync\Engine\Source\Runtime\Launch\Private\Windows\LaunchWindows.cpp:258]
UnrealEditor!WinMain() [D:\build\++UE5\Sync\Engine\Source\Runtime\Launch\Private\Windows\LaunchWindows.cpp:298]
UnrealEditor!__scrt_common_main_seh() [D:\a\_work\1\s\src\vctools\crt\vcstartup\src\startup\exe_common.inl:288]
kernel32
ntdll
The support on this forum is garbage.
I need more details to investigate the issue:
Specific version of UE,
Specific version of Ornatrix,
Exact procedure or specific actions that cause the crash.
Experiencing same here.  No ground strands issue in 5.1.  Will post details soon.
