Select the guide with hotkeys without need to choose selecting tool when using move tool or other from edit guide operator?
Posted by:britva_27
Data created:10 March 2020
there are away when using move tool or other tools from edit guide node to select the guide with hotkeys without need to choose selecting tool?
Not yet but we are looking into this. In Maya holding shift will activate the Selection brush regardless of what brush is currently selected, we may implement something similar in C4D.
Great. Thanks. it will be very comfortable if you add plant guide brush because it often used tool and have to constantly run between edit mode from root to brush
Already implemented in C4D, using the SHIFT key.
