Apply Guide length
Posted by:holger.biebrach@gmail.com
Data created:18 April 2020
Hello, I am fairly new to Ornatrix and try to do following. I need to apply a certain length to selected Guides. Is that possible? If not could it be possible to write a custom python Brush that does that? I know the is the Length-Brush to change length. But I need to apply the very same length to certain Guides.
As you said you can use the Length brush. Just set the minimum and maximum length to the same value and the brush will set it directly. If you know Python you can write your own length brush. Find the documentation for custom brushes HERE.
