distribute the simulation across several animation cache nodes
Posted by:britva_27
Data created:26 June 2020
Can I split the simulation into several animation cache modifiers? Write in the cache first part of the simulation in one animation cache node and then submit its last position as the initial one to continue the simulation, which I will write to the second animation cache node.
This is not possible but is a good idea, I will discuss this with the team. Thank you!
