Edit Guides doesn't work properly in C4D S22
Posted by:ktheorin1@gmail.com
Data created:24 August 2020
In Cinema 4D S22, it seems that the edit guides operator isn't working properly. In edit mode, you can't use anything but "select all" to select hairs. Neither live select nor rect select are working at all. The brush tool doesn't work at all because of this. All of this work normally in Cinema 4D R19, so I'm not sure what would be the difference here. I've tried every recent version available on the site, but they all seem to be broken. Do you know what the issue might be here?
In early builds of C4D S22 there is a bug with C4D matrices that prevent Ox from working correctly. Please upgrade to the latest R22 build and try again.
Yep, that worked! Thanks so much!
