Ornatrix Arnold IPR Rendering Issue Logs
Posted by:artofblaq
Data created:24 October 2021
Greetings team,
Arnold Ornatrix rendering, IPR Mode issue Logs.
Should I be worried if the "Ornatrix Warning: Could not load Moov library" keeps showing up in the log? If so How do I fix it?
There's this also which comes often anytime I create a new groom group, "[c4dtoa] 00:00:42 6946MB WARNING | cannot declare uniform UINT curve_id on ////CAMILE_CHARACTER////GROOM/03B_2 - name already in use", How do I rectify this issue?
See below a log list for a scene I am currently working on. Please let me know your response ASAP.
Thank you!
Arnold IPR started at Sun Oct 24 14:28:50 2021
[c4dtoa] 00:00:02 7018MB WARNING | cannot declare uniform UINT curve_id on ////CAMILE_CHARACTER////GROOM/01_2 - name already in use
[c4dtoa] 00:00:02 7001MB WARNING | cannot declare uniform UINT curve_id on ////CAMILE_CHARACTER////GROOM/01B_2 - name already in use
[c4dtoa] 00:00:02 6980MB WARNING | cannot declare uniform UINT curve_id on ////CAMILE_CHARACTER////GROOM/02_2 - name already in use
[c4dtoa] 00:00:02 6965MB WARNING | cannot declare uniform UINT curve_id on ////CAMILE_CHARACTER////GROOM/02B_2 - name already in use
[c4dtoa] 00:00:02 6954MB WARNING | cannot declare uniform UINT curve_id on ////CAMILE_CHARACTER////GROOM/03A_2 - name already in use
[c4dtoa] 00:00:02 6942MB WARNING | cannot declare uniform UINT curve_id on ////CAMILE_CHARACTER////GROOM/03B_2 - name already in use
[c4dtoa] 00:00:38 7022MB WARNING | cannot declare uniform UINT curve_id on ////CAMILE_CHARACTER////GROOM/01_2 - name already in use
[c4dtoa] 00:00:38 7000MB WARNING | cannot declare uniform UINT curve_id on ////CAMILE_CHARACTER////GROOM/01B_2 - name already in use
[c4dtoa] 00:00:38 6978MB WARNING | cannot declare uniform UINT curve_id on ////CAMILE_CHARACTER////GROOM/02_2 - name already in use
[c4dtoa] 00:00:38 6963MB WARNING | cannot declare uniform UINT curve_id on ////CAMILE_CHARACTER////GROOM/02B_2 - name already in use
[c4dtoa] 00:00:38 6951MB WARNING | cannot declare uniform UINT curve_id on ////CAMILE_CHARACTER////GROOM/03A_2 - name already in use
[c4dtoa] 00:00:38 6937MB WARNING | cannot declare uniform UINT curve_id on ////CAMILE_CHARACTER////GROOM/03B_2 - name already in use
[c4dtoa] 00:00:39 7028MB WARNING | cannot declare uniform UINT curve_id on ////CAMILE_CHARACTER////GROOM/01_2 - name already in use
[c4dtoa] 00:00:39 7006MB WARNING | cannot declare uniform UINT curve_id on ////CAMILE_CHARACTER////GROOM/01B_2 - name already in use
[c4dtoa] 00:00:39 6984MB WARNING | cannot declare uniform UINT curve_id on ////CAMILE_CHARACTER////GROOM/02_2 - name already in use
[c4dtoa] 00:00:39 6969MB WARNING | cannot declare uniform UINT curve_id on ////CAMILE_CHARACTER////GROOM/02B_2 - name already in use
[c4dtoa] 00:00:39 6957MB WARNING | cannot declare uniform UINT curve_id on ////CAMILE_CHARACTER////GROOM/03A_2 - name already in use
[c4dtoa] 00:00:39 6943MB WARNING | cannot declare uniform UINT curve_id on ////CAMILE_CHARACTER////GROOM/03B_2 - name already in use
[c4dtoa] 00:00:41 7031MB WARNING | cannot declare uniform UINT curve_id on ////CAMILE_CHARACTER////GROOM/01_2 - name already in use
[c4dtoa] 00:00:41 7009MB WARNING | cannot declare uniform UINT curve_id on ////CAMILE_CHARACTER////GROOM/01B_2 - name already in use
[c4dtoa] 00:00:41 6987MB WARNING | cannot declare uniform UINT curve_id on ////CAMILE_CHARACTER////GROOM/02_2 - name already in use
[c4dtoa] 00:00:41 6972MB WARNING | cannot declare uniform UINT curve_id on ////CAMILE_CHARACTER////GROOM/02B_2 - name already in use
[c4dtoa] 00:00:41 6959MB WARNING | cannot declare uniform UINT curve_id on ////CAMILE_CHARACTER////GROOM/03A_2 - name already in use
[c4dtoa] 00:00:41 6946MB WARNING | cannot declare uniform UINT curve_id on ////CAMILE_CHARACTER////GROOM/03B_2 - name already in use
[c4dtoa] 00:00:42 7031MB WARNING | cannot declare uniform UINT curve_id on ////CAMILE_CHARACTER////GROOM/01_2 - name already in use
[c4dtoa] 00:00:42 7009MB WARNING | cannot declare uniform UINT curve_id on ////CAMILE_CHARACTER////GROOM/01B_2 - name already in use
[c4dtoa] 00:00:42 6987MB WARNING | cannot declare uniform UINT curve_id on ////CAMILE_CHARACTER////GROOM/02_2 - name already in use
[c4dtoa] 00:00:42 6972MB WARNING | cannot declare uniform UINT curve_id on ////CAMILE_CHARACTER////GROOM/02B_2 - name already in use
[c4dtoa] 00:00:42 6959MB WARNING | cannot declare uniform UINT curve_id on ////CAMILE_CHARACTER////GROOM/03A_2 - name already in use
Sorry, I missed this post. Are you still getting this warning?
Yes, I am every time any of the groom nodes is selected it just log the ornatrix warning as well as the curve_id issue. I am not really sure why.
I see. Let's debug it together. Try this:
  1. Find the hair object that is giving triggering all the warnings, delete the rest.
  2. Inside this hair object, find one node that is triggering the warning. Delete as much nodes as you can as long as you can still reproduce the issue.
  3. Delete every object in the scene that is NOT related to Ornatrix and the hair.
  4. Send me the scene to jeordanis .f (at) ephere .com.
This is to get a scene as clean as possible but still being able to reproduce the issue.
If you have difficulties with this, just send me the scene and I will do it myself.
The "Ornatrix Warning: Could not load Moov library" is not important and appears by mistake. It will disappear after revision <span>29131.</span>
<span>For the other warning we'll need an example scene, as Jeordanis described.</span>
