Distribution Multiplier doesn't work on loaded images(B/W)
Posted by:artofblaq
Data created:2 February 2022
I have a groom and the density is driven by a density mask, but for some reason, the mask doesn't affect the strands. I have tried using c4d's noise shader to test out which works as expected but my loaded mask doesn't affect the look. Is this a bug?
I am on Cinema 4D r23.110 and ornatrix(most latest version)
It sounds like a bug we fixed a couple of weeks ago. Please make sure that you are on the latest nightly build. Also try reloading the bitmap, save and reload the scene.
I got the same issue. But I have a workaround it.
Quick question: how do I shade the hair by using the strands group as user data for masking with Arnold?
I got the same issue <span>2.3.1.29748</span>
Are you guys using the latest nightly build?
