1. If you can export C4D hair to Alembic then you can import it back as Ornatrix alembic. That will convert it to Ornatrix hair.
2. If you can convert C4D hair to curves, then in Ornatrix you can use the Hair from Curves preset to convert it to Ornatrix hair.
3. If you can convert C4D hair to polygon strips, then in Ornatrix you can use Hair from Mesh Strips modifier to convert it to Ornatrix hair.
