Is it possible to lock the rotation of strands?
Posted by:sca1991
Data created:7 April 2022
Hi!
I'm trying to use a sweep Nurbs in C4D, using an instance of the Curves from strands modifier, however i dont know of any way to lock the rotations of the strands.
I notice proxy mesh from strands does lock the rotation, however i would like more control over my meshes and a sweep nurbs provides this, any suggestions?
>2022-04-06+13-55-04.mp4 (3792976 bytes),
Sorry, I removed your first post by mistake. Thank you for posting it again.
You don't want the strands to rotate your proxy meshes? Try disabling Inherit Rotation in Mesh from Strands > Proxy Meshes.
I actually would like to aovoid using mesh from strands and use C4Ds native system to sweep a mesh along a curve. Is it possible to lock the rotation of curves instead?
We don't have that feature but try adding a Ground Strands modifier, ground the roots and uncheck Rotations.
I wasnt able to produce results where the strands rotations are locked using ground modifier.
How might i go about creating material variation with proxy meshes? I am using a procedural Redshift shader
Best
Sam
