hair from mesh strips to specify individual colors
Posted by:hoil
Data created:2 May 2022
Hello, I'd like to ask you something during the hair test using the demo version. When you use hair from mesh strips to do hair work, if you put texture in the redshift material, the color doesn't change from the root, but the pattern goes into the hair. I want to make a pattern by adding color from the roots, so how should I approach it?
Are you trying to apply per-vertex color to the hair and using it in a Redshift render? If so, Redshift does not support Ornatrix per-vertex color. Unfortunately.
Are there any other renderers available other than redshift? And how will it be applied?
This feature is only supported by Arnold renderer. Ornatrix provides per-strand channel colors and per-vertex channel colors. Redshift only supports the first one, Arnold supports both.
