When I add a Redshift object Tag, there's no apparent change to my render. If possible I'd like to use the "hair strands" option in the Redshift Object Tag because its better with memory than using geo. Is there a way around this?
I'm not sure if I understand the issue. You don't need to add any tags to render Ornatrix hair with Redshift. It is supported natively, it is not using triangles, it uses hair primitives.
