when you copy a model with hair into a new project, the hair is not copied. Copied noticed only the groom in which there is a guide from mesh. If their 0 is specified and added via edit guides, then the hair is not copied |
| I just tried it and it works. Are you using distribution maps? Check if they are being copied correctly. Check if the guide data is being copied. If the guides that you planted are still in Edit Guides, the guide data is correct. Jeordanis Figuereo (Product Designer. EPHERE Inc.) |
| Strength but I tried today and it works also for me. I'm using vertex maps, they are more convenient than texture maps for me.
But also I'd like to note that often hangs the viewport on dead. I can't even figure out when this is happening. Under different situations. This happens in R25 and R26 as well. Although the program buttons are responsive, you can even save the project. Only restarting the program helps. This is very annoying. ornatrix 2.3.7.30899 and <span>3.0.1.30888</span> |
| If you can pin point where this happens we can debug it and fix it. Any clue would help us, and the scene of course. Jeordanis Figuereo (Product Designer. EPHERE Inc.) |
