can't log in / c4d / macOS
Posted by:rrot31
Data created:6 October 2022
it's not connecting to any servers. it's the second time within some weeks. How can I solve this? is there something like an offline connection?
I'm having the same issue. How do you resolve it?
I've tried removed the ~/.local/share/Ephere folder contents and license text files, then reinstalling the plugin. C4D still hangs on initializing plugins, prompts for Ornatrix license server, but no options in that window work. Also tried releasing the license from the account page. Can you provide information on what is happening. Is this a result of your license server not being available? If so when can it be available and how can I ensure it doesn't happen as I am wanting to use the plugin for a commercial project with tight deadlines?
Our central license server at ephere.com had stopped without a notice. It is back up now, online licensing should work.
In general, to avoid depending on our central license server you can install a license server locally. But you may experience a different kind of problems (like having to reinstall it if your hardware changes).
From now on we'll take better care to keep the LS at ephere.com running.
