Ability to set the number of points separately for physical simulation
Posted by:britva_27
Data created:11 November 2022
I noticed that in the ornatrix the simulation of physics would work normally, it is necessary to have from 8 to 16 points per hair. if you have more, they begin to fall apart or float like in water.
Often for long hair, this amount is not enough for a normal shape (especially at the hair root where the main direction of the hair is formed), even if you add a detail operator and increase the number of points in it. The built-in hair tool in cinema 4d has the ability to separately set the number of points that are used in the simulation.
>2022-11-11+12-38-34.mp4 (11724119 bytes),
Can you record a video showing the issue with Ornatrix?
Hi. No, I mean that it is like a new feature that can help simulate hairs with less computing power. I drop an example of how it works in the native cinema 4d hair system.
If you show me how the lack of this feature in Ornatrix affects the simulation I will be able to understand the issue better and try to find the best way to implement a solution, or even see if Ornatrix already have something similar implemented.
I think it is possible to use the Detail operator to increase strand detail after it has been animated by Moov at a lower point count (i.e. generate the initial hair with a low point count, apply Moov and simulate, then apply Detail on top of Moov and use it to increase the point count).
But in general, I think Moov should be able to handle larger point counts too, so yes, an example scene showing how increasing the point count breaks the simulation would be useful.
