| Posted by: | Bibby | |
| Data created: | 26 November 2022 | |
Hi, I've been able to solve the freezing by the lowering the haircount below 100, however that still only gives me 5 fps in the viewport and being able to only have less than 100 hairs on an animated charcter's head in the render is simply not acceptable. My grandfather has more hair than that. And this performance issue is not scene-dependant. It's happening just as adversely on a default Furball preset scene with all default settings. Is this a known issue or am I missing something here? If anyone has any advice, it would be much apreciated. Here are my specs: C4D R23.110 Ornatrix 2.3.0.29616 CPU: Intel i7-6850K RAM: 16GB GPU: GTX 1080 Thanks | |
| 26 November 2022
#32054 | |
Hi, It shouldn't be that slow. however I have to see how you are using it and with what settings. Is always better to use Moov on the guides and not directly on the hair, unless you have the CPU power to handle such heavy simulation. Moov will simulate the guides and the guides will move the hair. Regarding the crash, try to reproduce it consistently and show me the steps to reproduce it. We will address the crash as soon as possible. Jeordanis Figuereo (Product Designer. EPHERE Inc.) | |
| 27 November 2022
#32055 | |
Hi, I put the Moov modifier under the Guides from Mesh modifier as you suggested, and my performance increased from 1 fps to 12-14 fps without lowering the hair count. This is already an immense improvement, but is there a way to optimize the playback even further? I coudn't find where to change the hair point count, that option only seems to be available in the Guides From Mesh modifier. Or is this what the Details modifier is for? Also, in regards to collisions, I'm encountering a few issues: - Enabling Collide With Base Mesh causes C4D to freeze even with low hair count on a default sphere - Collisions with other objects still causes hair clipping even with the physics Substep and Iterations at maximum values and all meshes being designated in the Collision Meshes tab. - Enabling Collide With Hair causes hair to ignore all other objects even when they are designated as collision meshes. - Hair simulation won't respond to C4D Force objects (E.g. Wind). So far, my workaround has been to put the distribution mesh into the Collision Meshes tab and to use the Push Away From Surface modifier, although that isn't perfect either.
Here is my example scene file. Any advice on my hair setup would be greatly appreciated. Thanks | |
| 3 December 2022
#32088 | |
Hello? | |
| 3 December 2022
#32089 | |
Hi, This is how it runs for me without any modifications to the scene:
I belive that the Basic Concepts tutorial will help you understand how Ornatrix hair data flows in the modifier stack, so you will be able to optimize the stack for faster rendering and simulation. This one as well.
Yes. Use the Details modifier to set the amount of strand points for each strand. Check out the docs here to learn how to use it.
I cannot reproduce this crash(See the gif below). I tried with the latest nightly build of Ornatrix. Please update it if you haven't and try it again:
Also, your base mesh is also set a collision mesh in the Object Tab -> Collision Meshes. This is not necesary, just enable Collide With Base Mesh.
See the Collision Tolerance parameter in Moov Physics docs. This is what you are looking for in this case instead of increasing the Substep Count or Iteration Count parameters.
I cannot reproduce this either. Update Ornatrix and try again.
Ornatrix is not compatible with C4D's default Force objects. So far Maxon has not exposed those to the C4D SDK for plugin developers. As a solution(for Wind only), we provide a script that will help you create easy wind hair animation. This tutorial is Ornatrix for Maya but you can follow the exact same steps in C4D to add wind to the simulation.
Ah. Now I see why you did that. Jeordanis Figuereo (Product Designer. EPHERE Inc.) | |
| 6 December 2022
#32096 | |
Hi, Updateing to the latest stable verson of 2.3.8 doesn't fix any of the afformentioned issues for me except the hair-to-hair collision one. - Enabling base mesh collision still causes crashing or 0.1 fps in viewport (this is why in my scene, I put the base mesh into the collisions tab to circumvent this). - Caching physics with base mesh collision enabled (if it doesn't crash) shows a result as if no collisions were ever enabled (strands fall right through the mesh). - Collsion Tolerance still doesn't seem to affect anything. - The Wind Simulator script doesn't work at all. I checked the Maya tutorial on Youtube, and I seem to be doing everything correctly, so I don't know whats wrong there. Thanks
| 6 December 2022
#32101 | |
Can you provide a scene where this crash happens? The one that you posted here doesn't have that problem. I can't reproduce it there.
I cached the simulation in your scene using the Animation Cache. I didn't get any crash and the collision seems to be working as expected:
Same as above. As shown in the gif the guides are colliding with the spheres even with the default value.
Finally, I tested the HairSimulatorWind script, as shown below it is working as expected:
Do you have another version of C4D that you can try? Just to discard that those issues that you are having are related to a specific version. Jeordanis Figuereo (Product Designer. EPHERE Inc.) | |
