Hello guys.
I'm currently experiencing a lot of issue with Ornatrix V3and edit tool, wathever the version of C4D.
One of them is that sometime, selecting hairs carefully lead to a lot of unwanted hairs to be selected (far from the source selection).
You can see it in action on the video (R23 and R26 tests).
Longest are the hairs and worst it is.
I use to reset my hairs to 1cm to make selections when I can, but in many case, it's not possible.
Shift key to had selection also often bugs and isn't taken into account.
When this happen, we have to undo, press shift, retry.
And the bad days, re-undo, re-shift press, re-try again until 5 or 10 times.
This is impossible to reproduce.
Even if everything work perfectly in a scene, at somme point, it bugs ... then re-work ...
In a more general way, a fonctionality to not select hairs that are behind the character mesh will be really appreciated :-)
