Posted by: | ![]() | FlowS |
Data created: | 14 January 2023 |
Hello, The "Hair From Guides" doesn't work with maps when "Guide as Hair" Mode is used. That will be a necessary feature, because we often need to reduce hairs to drive some fonctions. For example, we can want to reduce a baked hairs comb to generate guides, and use these guides in a "Clump by external guide" applied to an istance of this bake hair comb. We also need to reduce a hair comb to few guides to animate the hairs with "Adopt external guides" operator. And when we use these fonctions, It's better if it's just a reducing of the original hairs number than a re-interpretation produced by "even" mode for example. So, If "Guide as Hair" could be simply reduced by a grey texture for example, it will be greatfull ! | |
16 January 2023
#32287 | |
19 January 2023
#32297 | |
Thank you | |
23 January 2023
#32317 | |
