In the edit guide operator when you try to select guides at first and after want to continue selection with the pressed SHIFT button and clicking LMB all previous guides will be unselected
The selection works as expected from the tests. Pressing SHIFT + LMB will add to the selection without removing the previous selection. What version of C4D are you on?
also, the baking modifier works incorrectly
Can you elaborate? I need more information.
also, the viewport freezes when in the ornatrix tag is checked viewport lights when I use redshift render. This issue are olso in last stable 2V ornatrix
We are aware of this one and it is still in our list of priorities.
