Ornatrix C4D "Render only" version?
Posted by:vc-fur-feather
Data created:10 July 2025
We use several workstations. Some are dedicated render nodes, while others are used by artists during the day for C4D work and switch to command line rendering via Deadline at night.
Ornatrix is only actively used on one workstation with C4D.
When Ornatrix is installed on a workstation that is used by artists (who do not work with Ornatrix, but where it is needed for Deadline rendering overnight), the license window always appears when launching C4D and must be closed manually.
My question:<br data-start="580" data-end="583">Is there a "render node only" version of Ornatrix available, similar to X-Particles?<br data-start="667" data-end="670">Or is there a way to specify that the plugin should be used for rendering only on certain machines, so the license window does not appear?
Thanks,<br data-start="817" data-end="820">Thomas
<br>P.S. Is there a way to search the forum ;)
This seems possible to implement, we'll consider it.
<br>Thank you for the missing Search reminder.
