Cant get install to work with c4d 2025
Posted by:Spenc3r
Data created:4 November 2025
I think i licenced things right through terminal but I truly cannot get any kind of menu to appear in c4d 2025, any advice appreciated.
Terminal? Are you on MacOS?
Which are your exact C4D and Ornatrix versions?
Yes im on Mac Sonoma 14.1.2 apple mac book pro with M1 chip, C4D 2025.3.3 and Ornatrix C4d V3 "3.1.3.37049 [Latest Stable
What's this?
Got C4d open with Rosetta and have it working, curse you mac pc wars// is the flow right now for apple silicon -- use Ornatrix w CPU only, bake what you can, then turn GPU back on badda bing badda boom?
Oop jk trying to use anything causes fatal crash
Ornatrix V3 is x86-only and yes, you have to start C4D with Rosetta to use it.
Ornatrix versions since 4.0.2 switched to ARM.
No, we cannot backport ARM support to V3.
For an unknown reason, Ornatrix won't show up in the viewport in C4D 2025.3 on Windows. I'm not sure about Mac, I don't remember if it had the same problem, but I would be suspicious in general about using Ornatrix with 2025.3.
2025.2 and 2026 have no known problems.
