hey there! :) i just installed the plugin to the plugins folder under osx, but ornatrix doesn't show up in the plugin drop down. am i missing anything? thanks for your help! oly |
| Could be a missing dependency, let's wait for Roger to follow up. Marsel Khadiyev (Software Developer, EPHERE Inc.) |
| Hi! What R19 release are you running? Ornatrix was compiled for R19.053. |
| Hi! I am running R19.053 on OSX high sierrra 10.13.05. I just put the folder in the "plugins" folder. |
| Be sure to follow the last two steps of the installation: * Copy Ornatrix.cdl64 from the sub-directory matching your Cinema 4D release one level up into the Ornatrix directory
* Copy tbb.dll to the Cinema4D root directory Jeordanis Figuereo (Product Designer. EPHERE Inc.) |
| Hi phantom, Can you try a new build? On macs, there's no need to move the tbb dll anymore, so just installing Ornatrix in the plugins folder should be enough. If you still have any problem, I'll need some logs to find what's breaking the plugin initialization |
| Hi I'm also having a problem on OSX - the plugin installs but there are no options in any of the tags? See the screenshot here: https://www.dropbox.com/s/0zm4rrbb5xxu6ok/Screen%20Shot%202018-10-09%20at%2008.13.45.png?dl=0 I'm sure i have just put something in the wrong place, but I've tried installing a few different builds and keep getting the same result. Any clue as to what I am doing wrong? Thanks in advance! Chris |
| Which is you C4D version, R19 or R20? I just tested with R19 and it's OK. Ivan Kolev (Software Developer, EPHERE Inc.) Discord: ikolev Email: ivan.kolev at ephere com |
| It's R19 i'm running. Any suggestions as to what I should try? |
| Looks like an installation problem. But it's not as simple as missing icons. You have just 4 question mark icons in the screenshot, meaning 4 tags, while I see 5 tags (with their icons) here. The first tag is a "Hair Material Expression", then "Guides from Mesh", etc. until "Change Width" at the end. I'm looking at the tooltips that appear. Do you get tooltips on the ? icons? Ivan Kolev (Software Developer, EPHERE Inc.) Discord: ikolev Email: ivan.kolev at ephere com |
| I dont really see anything with the question mark icons - there's nothing in the attributes manager (see screenshot) and when i hover over them it just says 'expression' https://www.dropbox.com/s/lpyyf89abwzkuev/Screen%20Shot%202018-10-09%20at%2020.28.14.png?dl=0 |
| Which build are you using? Recent Mac builds have deployment errors and won't load at all. It'll take a few days to fix. Ivan Kolev (Software Developer, EPHERE Inc.) Discord: ikolev Email: ivan.kolev at ephere com |
| 17303 for Mac is up, verified to work with R19 and R20. One important detail of the manual installation is to *move* the plugin file from the R19 or R20 directory, not copy it. Updated the Readme. Ivan Kolev (Software Developer, EPHERE Inc.) Discord: ikolev Email: ivan.kolev at ephere com |
| version 17303 works! Thank you for your help! - i look forward to learning this plugin now! |
