Nightly builds?
Posted by:ilay7k
Data created:26 September 2018
(0 - 25 of 35) 12 Next »
Hello Marsel
Have Nightly builds any upgdates/upgrades, in downloads shows N/A info? Or simple dayly auto-builds?
Ouch, i see from Ver. 0.0.2.17050, remove command make groom from selection
We've been having some issues with building for R20 so nightlies have not ben built for a few days. I hope we can get this resolved tomorrow.
Make groom command didn't work (wasn't hooked up) anyway so we decided to disable it for now. We'll re-add it when groom generation is supported.
Thank you.
upd.
Thanks to Ephere team that supports r20
I update last build(Ornatrix-C4D-0-0-2-17109-win64) for r19 and install for r20, but got errors with loadnig resourses at strings
TEditGuides.res - str 149 if comment it, will disappear with controls ;)
TGuidesFromMesh.res - str 133
THairFromGuides.res - str 132
Yes, i have the same error.
Even comment, especially customgui, also i can't work with brushes in edit guides.
confirmed here as well unusable with R20.
Hi!
This error has been fixed today, please get the next nightly build.
Hello Roger
Thank you. I will.
Upd.
0-0-2-17123 works!
0-0-3-17234
1. QT gui, for what? Just curious.
2. new test commands: unit test and sdk example(crashes c4d)
upd.
for what scripts needs unit test? python scripting for Ornatrix-C4D?
Hello team
Does Parting of Hair From Guides work? or W-I-P?
At least the auto-part feature should be working, not sure why it is disabled at the moment. Will wait for Roger to clarify.
Hi!
The Sdk Example is WIP, working on Mac but has some issues on Windows.
Partings are not complete yet, so we disabled. I didn't try the auto-part, will make a quick test and enable if it's functioning properly.
Thank you both for replies!
Ornatrix Tag [Push Away from Surface] in new Ornatrix-C4D-0-0-3-17360, this separate effector-tag does not work, wip?
I tested the Push Away from Surface tag and it really does not work!
Yes, the tag at the moment is lacking the collision meshes, should be implemented soon.
THANKS!!!
Laughing
Thank you. Of course fuction in Edit tag works
I touched non last night build and new tag-modifier Push Away works fine for me
Hi to all
I got a strange thing with Ornatrix-C4D-0-0-4-17765-win64 while adding of hair
Load resource error: symbol not found hfg_InterpolationTypeAttribute. (file:///plugins/Ornatrix/res/description/thairfromguides.res) [res_basecontainer.cpp(2614)]
ok, I load res files from earlier version 0-0-4-17718
I will compare res files, but interesting glitch
Ornatrix-C4D-0-0-4-17775-win64, 7z file used
same error like in last post
upd.
Old in header, not in res file
    hfg_OldInterpolationTypeAttribute,
    hfg_OldInterpolationGuideCountAttribute,
Ornatrix-C4D-0-0-4-17783-win64.7z  file used
same error as above.
By the way, thank you for your hard work, appreciated very much.
kind regards.
M
