Hello
I noticed that within the edit guides tag/strands mode I have the ability to select only certain guide points using the control points and influence. Id like the move, scale and rotate handles to be placed at a chosen pivot position in order to rotate or scale hair from that positon but it seems the control position is the point in which the influence starts from but in both directions, in other words from the middle outward, I cant move the axis handle so how do I change the pivot positon?
Second thing id like to know is how can I select only certain vertex points for use in Brush mode, like for instance the Move brush. I see that there is a good amount of control over operators/tags via the channle and paint brush, thats nice, but dont see such control via the groom brushes to limit their effect on a vert by vertex basis?
Thanks, Dan
