Ornatrix c4d sélection tag only
Posted by:Cchumi
Data created:28 November 2018
hi everybody I try to assign ornatrix hair to c4d selection only. I have a teddy bear and I would like to have different hair on different part.
How can I achieve that ?
thanks
pierre
Hair from selection is not implemented yet. As a workaround you can extract parts of the mesh as different objects and apply a different hair object to each, then maybe you can attach or skin wrap those extracted meshes to the teddy bear.
Hi to all
New Modifier based version still has selection sets
@ilay7k where to get that python script from ?
I made it by self. It's wip
I add 3 modifiers, no materials. User sets them by self
I don't understand why I cannot use the latest Ornatrix 0.5 after installing 0.4 with the pkg so i download the latest Zip file and extract the plugin in the C4D plugin folder.
And I got the latest version with deformer.
I Give it a try.
Thanks a lot
@ilay7k thanks a lot for sharing, I´m not a coder so can´t do such things ;)
Thank you I am not a very good developper so I wait this for the implementation.
I just downloaded and installed the 0.4 pkg on the Mac, it worked in both C4D R19 and R20, then downloaded and installed the 0.5 stable pkg on top of it, it also worked in both R19 and R20.
Please give me some details (open a new thread) if you have any problems with the pkg installer on the Mac. I think there is a way to run the installer with logging, I'll check if needed.
