Ornatrix and C4dtoA quick test of a beard!
Posted by:dragofx
Data created:25 December 2018
[IMG]http://i63.tinypic.com/9hsajs.jpg[/IMG] [IMG]http://i67.tinypic.com/117hc0h.jpg[/IMG]
To post an image use the Insert/Edit Image button on top of the post text editor.
Great work!
Looks great. May I ask how you changed the thickness of the hair? I can't seem to change this setting when using Ornatrix and Arnold.
Thanks in advance
To control the thickness on the arnold add the curve tag and the curve width - scale tab, set the curve to the same value as the ornatrix!
Arnold doesn't render the hair. I am using R20. Is there a setup I can follow using Arnold?
Arnold is not officialy suported yet. As a workaround you can add the CurvesFromStrands operator to the hair, then add the Arnold Parameters tag. This will allow you to render the hair as curves.
