very thanks, i build "add action to 3dsmax main menu" , it's work ,but , after i delete this dll =..= This can be auto cleared when delete plugin.dll ? Attached Files: |
| The menu entries can only be manually cleared. You would need to have an uninstaller script remove them. This is the only way I know. Marsel Khadiyev (Software Developer, EPHERE Inc.) |
| thanks, i hope show winform in ActionItem ExecuteAction mehod public override bool ExecuteAction() { // execute me TestForm dialog = new TestForm(global); dialog.Show(); return true; } how to get IGlobal global? |
| You need to create a class derived from IPlugin. IGlobal is passed into Initialize(...) method. Marsel Khadiyev (Software Developer, EPHERE Inc.) |
| public override bool ExecuteAction() { MessageBox.Show("ok"); return true; }
public override bool Execute() { MessageBox.Show("ok Execute"); return true; } when i click menuitem , No any response |
| You could have your plugin destroy all the menu stuff on application close. |
| why,my test project,menu cannot execute action? |
| why cannot execute action? who can help me? thanks |
| I am going to test this now, will let you know what I find. Marsel Khadiyev (Software Developer, EPHERE Inc.) |
| I forgot to mention adding MyActionCallback callback class. I have updated the documentation to reflect this. I'm also attaching your updated code that should work now. Marsel Khadiyev (Software Developer, EPHERE Inc.) |
| very very thank you,i am a newbie,In the past I use only MaxScript thank you |
| No problem, post any questions if you have them and I'll try to answer. Marsel Khadiyev (Software Developer, EPHERE Inc.) |
| "You could have your plugin destroy all the menu stuff on application close." I searching Sdk Document with what key word? |
| By that I meant "void MenusAndActionsUnregister()" function. You can add code there to remove your menu entry before plugin unloads. Marsel Khadiyev (Software Developer, EPHERE Inc.) |
| thank you , i dont know how to do like MaxScript code with max.net --------------------------------- callbacks.addScript #preSystemShutdown "xxxxxx()" -------------------------------- |
| class TestExitCallBack : IExitMAXCallback { Test theTest;
public TestExitCallBack(Test theTest) { this.theTest = theTest; }
public bool Exit(IntPtr hWnd) { theTest.MenusAndActionsUnregister(); return true; }
public void Dispose() {
public bool Equals(IExitMAXCallback pIExitMAXCallback) { return true; } } MaxGlobal.COREInterface.RegisterExitMAXCallback(new TestExitCallBack(this)); cant execute O_O |
| Please derive your class from Autodesk.Max.Plugins.ExitMAXCallback, not IExitMAXCallback. You always derive from class in Plugins namespace. Also have a look here. Marsel Khadiyev (Software Developer, EPHERE Inc.) |
