how to get view select range?
Posted by:SITT
Data created:7 May 2010
like this image
what method?
select range on view
You need to specify render region in CurRendererRenderFrame, here's the excerpt from SDK help:
virtual int Interface::CurRendererRenderFrame (  TimeValue  t,
Bitmap *  bm,
RendProgressCallback *  prog = NULL,
float  frameDur = 1.0f,
ViewParams *  vp = NULL,
RECT *  regionRect = NULL
)  [pure virtual]
Remarks:
This method is called to render a frame to the given bitmap. The renderer uses the width, height, and aspect ratio of the specified bitmap to control the size of the rendered image.
Parameters:
TimeValue t
The time to render the image.
Bitmap *bm
The bitmap to render to. This bitmap defines the size and aspect ratio of the render. See Class Bitmap.
RendProgressCallback *prog=NULL
The RendProgressCallback is an optional callback. See Class RendProgressCallback.
This parameter should always be set to 1.0.
ViewParams *vp=NULL
This parameter allows you to specify a different view transformation on each render call. For instance, you can render a given scene at a given time from many different viewpoints, without calling Render::Open() for each one.
RECT *regionRect = NULL
This value, if passed, defines the region to be rendererd. This only works for RENDTYPE_REGION and RENDTYPE_REGIONCROP.
Returns:
The result of the render - Nonzero if success; otherwise 0.
thanks,i know rendType enum
i would,can pressed and move mouse,get this action  range
i want to do like this MaxScript,
tool SelectViewRange
    local StartPos,EndPos
    on mouseMove clickno do
        if StartPos == undefined do StartPos = ViewPoint
        EndPos = ViewPoint
    on stop do #(StartPos.X,StartPos.Y,EndPos.X,EndPos.Y)
StartTool SelectViewRange NumPoints:1
O_o o_O
This MaxScript can convert to max.net code
It would be a lot more complicated with SDK (need to push a new command mode and implement the mouse callbacks). If you can just execute that maxscript code using ExecuteScript(...)
