| Data created: | 5 February 2019 | |
New: Added an option to add strand detail by length New: Added a parameter to rotate clump patterns around the clump's stem New: Added a way to match control and reference strands in Adopt External Guides modifier using distance New: Added Chinese localization New: Changed default root distribution to Even Fixed: Installed Ornatrix toolbar does not contain new operators Fixed: Moov strand stiffness different in different parts of the hair object Fixed: Crash when using Round clumps option with manually selected clumps and a clump pattern Fixed: "Use Sequential Ids" option doesn't produce sequential root ids with Vertex and Even distributions Fixed: Moov: Cosserat model bug with root holder Fixed: GenerateStrandData is wrong when using the "is inside object" generation method Fixed: MoovPhysics: Particle mass parameters to have a more predictable effect on the simulation Fixed: HairFromMeshStrips: "Add Strip ID Channel" option adds too many channels and doesn't properly update the output Fixed: HairFromMeshStrips: Strand Groups are not applied correctly Marsel Khadiyev (Software Developer, EPHERE Inc.) |
