| Data created: | 27 September 2019 | |
New: Arnold hair rendering parameters in Ox Arnold modifier New: Support for per-vertex texture coordinates in Arnold render New: "Add Root Position Channel" option in Propagation modifier New: "Uniform randomness" parameter in Propagation modifier New: Curler axis parameter New: Add texture coordinate generation options to Scatter modifier Fixed: Edit Guides Control Point influence graph effect is not updated until Control Pointss are reselected Fixed: Oscillator crashes Max Fixed: Detailer produces exploding points with high smoothing point count Fixed: Using assign channel button in Scatter modifier crashes 3dsmax Fixed: Clump Modifier: Used Patterns list not updated properly Fixed: Propagated strands change drastically when frizzed with a non-0 value at root Fixed: Alembic import doesn't import width values Fixed: Frizzer shouldn't use strand length for curve diagram when length dependent option is on Fixed: Assertion when Curler "length dependent" option is on and strands have 0 length Fixed: Curler shouldn't use strand length for curve diagram when length dependent option is on Fixed: Scatter assertion when using input strand width option Marsel Khadiyev (Software Developer, EPHERE Inc.) |
