| Data created: | 11 October 2019 | |
New: Hair from Guides interpolates strand rotations New: Symmetry ensures that strand rotations are mirrored and that grounding doesn't affect them New: Brought back legacy "FK" brush algorithm when "Optimize Strand Geometry" option is off Fixed: Edit Guides: Control point affects more than one vertex for zero influence radius Fixed: Backward compatibility for Frizz operator diagram behavior change in last version Fixed: FrizzOperator: Amount Map is not affecting all the hairs Fixed: Multiplier doesn't copy guide dependencies Fixed: Legacy brush algorithm changes segment angles which are not view aligned Fixed: Proxy meshes are flattened Fixed: Hair displacement offset is not applied unless a map is also specified Fixed: Scatter causes errors with input hair which has invalid surface dependencies (e.g. if Symmetry was used) Fixed: Symmetry doesn't work with propagated strands Fixed: Scattered propagated strands produce errors Fixed: Loading a subset of hairs with varying point count causes instability and crashes Fixed: Changing propagated strand count causes incorrect clump assignment Fixed: Edit Guides amount parameter has no effect on strand rotations Fixed: Points too close to each other cause issues with Frizz Marsel Khadiyev (Software Developer, EPHERE Inc.) |
