| Data created: | 4 November 2020 | |
New: Show selected group number New: Randomization Map for the Length operator Fixed: GroundStrands changes strand positions Fixed: Crash when using Overwrite Input function in Animation modifier Fixed: Invalid texture coordinate values can be stored if allocated but not assigned Fixed: Hair From Guides not using strand ids when output count is 0 Fixed: Assertion with Create brush in Edit Guides on top of another Edit Guides Fixed: Degrading viewport performance in some scenes Fixed: FStorm ChangeWidth not working (supported in next FStorm build) Fixed: Guide Movement/Rotate on moving roots Fixed: Crash planting guide in Edit Guides on mesh Fixed: Surface Comb modifier not working with Strand Groups Fixed: Error: Strand grounder detected a degenerate triangle Fixed: Assertion when deleting strands without a surface mesh assigned Fixed: Unable to assign Strand Groups in some cases Fixed: Converting old scenes with triangles to polygons crashes if triangles have incorrect index Fixed: Clumper ignores strand group when generating clumps Fixed: Exported Alembic file sizes change when version string digit count changes Marsel Khadiyev (Software Developer, EPHERE Inc.) |
